Overlapping Rebar
Overlapping Rebar
Message 1 of 17
Overlapping Rebar
I am designing a 70x30m RCC slab with maximum rebar of 12m, using my slab as my reinforcement area. I would like an overlapping of 600mm min between each bar.
How can i set up and control the overlapping of my rebars?
AP
Replies (16)
Message 2 of 17
Ahmed_M_Heteba
Unfortunately you have to do it yourself.
you can use Area Reinforcement for 12 m long and draw another Area reinforcement for the rest with overlapping.
Also you can use Rebar in slab section view and draw the rebar with overlapping.
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 17
That's what i thought. I found quite frustrating that Revit doesn't have this option; lapping rebar is so commonly done when it comes to RC.
I'll probably use one of Autodesk extension that provides this feature.
Thanks for your help anyways.
Message 4 of 17
Amr.AbdelHai
Did you find any useful extension?
Message 5 of 17
 I HAD THE SAME PROBLEM YOU HAVE
THERE IS A REVIT APPLICATION NAMED 'SOFISTIK REINFORCEMENT DETAILING'
AND IT HAS 'SPLIT REBARS' FUNCTION
IT WILL SO THAT
YOU CAN DOWNLOAD FREE TRAIL THING FROM THE AUTODESK WEBSITE
GOOD LUCK
Message 6 of 17
I've been using SOFiSTiK Reinforcement Detailing 2018 for a while now, but Split Rebars function doesn't seem that helpful. Lots of bugs and errors. I'd recommend using the trail first. Maybe it works just fine with you.
Message 7 of 17
shefypattambi
Hi @Anonymous, @Anonymous,
 Sofistick could not split rebar inside area reinforcement. You have to remove the area reinforcement system in order to split it using Sofistick.
Message 8 of 17
YarUnderoaker
There is an Idea -  automatic rebar splitting
Please vote.
Message 9 of 17
semi
Use Naviate rebar extension
Message 10 of 17
EdwinG
You can make your own "Fabric Sheet" that does apply to your specs.
You can place them with "Fabric Area" down site is that you have to do it twice 1 for top and 1 for bottom area.
Message 11 of 17
is it easy to use in Naviate Rebar Extension?
I saw that still need to place the rebar by myself and use Naviate rebar extension to fixed the error only
Message 12 of 17
semi
Yes, see this example.
These are the settings for a beam 15m long:
Result:
Message 13 of 17
semi
We stopped using split rebars though as it isn't a good workflow.
We do it like in Autodesk Structural Detailing:
We place the rebar with its exact length - cover. Like a bar with length of 24m50 with Ø16 is scheduled with a formula so it gives us the correct length in the BBS: 2x overlap of 80cm: 26m10.
See the difference between modelled length and calculated length:
Message 14 of 17
But in this case making this "trick" you can have the right qto, but what about the rebar cuts in the flield??
Message 15 of 17
semi
what do u mean with rebar cuts in the fields? Can u give an example?
Message 16 of 17
I mean the cuts you need to make in the field when the element is longer
than the bar, and the cuts you need to make to optimize the rebar for waste
reduction.
Message 17 of 17
semi
We simply represent the formula and attach the image to it:
1 bar makes this easier than splitting the bar into 2.
