Northing on grids in elevations?
prucad12
prucad12
Community Visitor
Community Visitor
Hi all,
I am looking to add a northing to a vertical grid line in an elevation view. I can get it to snap to model geometry but not the grid lines.
Any tricks so it will select the grid lines??
ennujozlagam
are you in the active view? use your tab in your keyboard to select
What is a "northing" exactly?
ctm_mka
@ToanDN"northing" as in "Northing and Easting"  generally used in Civil for distance at a point from the projects origin. (so fancy X & Y values). @prucad12  Are you trying to snap to the grid outside the crop boundary? try snapping to it inside then moving it down.
I know northing and easting. I should be more clear to ask what element you used to present the information (tag, spot coordinates....)
