Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Northing on grids in elevations?
4 REPLIES 4
prucad12
193 Views, 4 Replies
Hi all,
I am looking to add a northing to a vertical grid line in an elevation view. I can get it to snap to model geometry but not the grid lines.
Any tricks so it will select the grid lines??
4 REPLIES 4
ennujozlagam
in reply to: prucad12
are you in the active view? use your tab in your keyboard to select
What is a "northing" exactly?
ctm_mka
@ToanDN"northing" as in "Northing and Easting"  generally used in Civil for distance at a point from the projects origin. (so fancy X & Y values). @prucad12  Are you trying to snap to the grid outside the crop boundary? try snapping to it inside then moving it down.
in reply to: ctm_mka
I know northing and easting. I should be more clear to ask what element you used to present the information (tag, spot coordinates....)
Forma Design Contest
