None of the created elements are visible in Floor Plan.
natcha.jita
natcha.jita
I have some problem about my work. When I created beam on my floor plan, it will show 'None of the created elements are visible in Floor Plan.' and eventhought I already check my visibility. How can I fixed it?
Thank you
They are below or above the view range. When place beam, pay attention to the properties to understand their elevation, associated level, offset, etc... Open a 3d view and see where they are.
ennujozlagam
go to the view that you be able to see your beam > go to view > view templates > create template from current view then apply to the view you cannot see your beam (properties > view template < apply the view template your created) then if you able to see the beam go to properties > view template and set to none.
or refer here
https://knowledge.autodesk.com/support/revit/learn-explore/caas/sfdcarticles/sfdcarticles/Revit-None...
