How to create a U-bolt as a structural connection?
IBIMKOREA
IBIMKOREA
Hello, I am a user working as a civil engineer in Korea. I found a question about u-bolts that are currently created with structural connections and an issue where u-bolts created with family modeling cannot be added when using Customize Structural Connections.
1. How to create a U-bolt as a structural connection?
2. U-bolts are not added to the user definition of structural connections. Is there a way?
REVITREVIT
3. If there is no workaround for both situations, is there another way other than placing family modeling?
P.s. When using the pipe strap function in Advanced Steel, it will only be generated at the end of the transverse direction. Is there a way to make it vertical?
ennujozlagam
you can download from here and modified? thanks
https://www.cadforum.cz/catalog_en/?q=Stock+U%2DBolt
IBIMKOREA
First of all, thanks for the reply. However No modeling required. I was wondering if there is a way to connect the U-Bolt structure (a function of program itself) instead.
