Non orthogonal section
LauB1975
LauB1975
Hello everyone, I’m trying to make a non orthogonal section of a slanted column. The section should be perpendicular to the axis of the column. I've been trying for several hours to do it by snapping to the faces of the column but the section tool seems to be orthogonal only. Is there a way to do this section as shown in the image below?
awes
Please check that your section view type is of detail view (all directions) and not section view (orthogonal).
veasnakimbitus
Hi @LauB1975,
Let follow this steps:
1. Cut section vertically follow the allow direction.
2. Use rotation commend and align with detail or reference line.
See VDO for more understanding. Hopefully it helps you.
(view in My Videos)
JL.FCG
I would usually draw detail lines to where you want your section to be cut in situations like this, and then draw your section along this line using snaps - or alternatively you could cut the section and then align the section marker to the detail line you drew!
LauB1975
Thank you so much @veasnakimbitus! That solution worked for me. Also thank you @awes and @JL.FCG for your suggestions!.
LauB1975
Thank you @JL.FCG for your answer this also worked in my model!
