Hi everyone! I am trying to make connections with a single bolt in a steel structure. The elements I want to join are L shaped profiles and a user defined profile which is a steel sheet folded at 60 degrees. The structure is a triangular guyed mast. I made several attempts to make the connection but I get this error “The shape for medium detail level of connected element contains rounding”. Which is true, both profiles have rounded surfaces to keep the fidelity of the model, but at the same time there should be enough space for one 1/2” bolt to connect both elements. In other attempts the bolt is misplaced, and the profiles overlap in space.
Below are images to clarify mi request. Thanks!.
