Need idea to model a Stair with Ramp
PrathapSekar
PrathapSekar
G'Day,
 In my project I need to model a staircase with ramp as shown in image below (sample downloaded from webpage). Please give me some Idea/Advise to proceed this. Thanks in advance.
Thank You! and please 'Accept As Solution' when you found a solution, to help others.
Revit_Whisperer
Ok....so this probably isn't the only way to do this...and it is not painless that's for sure...but this is all done with floors and is not complete, mostly just a process concept.Stair_ramp.png
PrathapSekar
Thanks @Revit_Whisperer,
We have modeled Floor instead of Stair and Ramp Is it acceptable in BIM model? Will it cause any problems while taking schedules? This model may not come under Stair/Ramp category right? Please clarify as i'm new to BIM. Thanks again.
L.Maas
As this seems to be a single instance I would consider to create this with a model in-place. Just use the modelling tools to create the stairs/ramp. You can then assign the stairs category. You also could create the ramp first with the ramp tool and then use the model in-place for the stair part.
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
i would suggest as enllnt said, model in place will be best choice , because in bim industry the categorization is very important
best,
Autodesk Expert Elite
