my first issue wit Revit 2021
andres_urrutia
Message 1 of 17
andres_urrutia
hello.
I'm trying to edit a connection in Revit... and guess what..
Replies (16)
Message 2 of 17
andres_urrutia
I've tryed in a second PC but the problema is the same. I can't edit the connections!!
Message 3 of 17
AntDrt
no problem from my side:
did you tried to re-install Revit ?
Antoine
AMG Fechoz
Serrurerie & Equipement Scénographique
www.amg-fechoz.com
Message 4 of 17
andres_urrutia
I've reinstalled in both computers and have the same issue. I can't see the connection parameters.
Message 5 of 17
andres_urrutia
I noted if I select my columns (made by myself), the connection is not able to be modified its parameters…. in the previous release that Works well.
Message 6 of 17
andres_urrutia
my problema is with tuve ent to end connection. I've tried even with section from the Revit library
Message 7 of 17
AntDrt
no problem again (tube end to end connection)
do you have any warning at the creation of the connection ?
did you tried others connections ? what language do you use ? have you tried to send a bug report to your reseller ?
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 8 of 17
andres_urrutia
I don't have any warning. if I override the connecton, is posible to change it. then copy to all the connections...
Message 9 of 17
AntDrt
can you send me your model ?
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 10 of 17
stefani.ads
If you haven't figured this out yet, we would also be interested in looking into it, so please also send me the model where this behaviour occurs.
stefani.ads
Message 11 of 17
andres_urrutia
model attached. thank you
Message 12 of 17
AntDrt
hum,
weird, same issue when editing your connection.
but, created others column, same size except, no special character like [] you put on your type name.
when i use copy identical function from your connection to my 2 new column, same bug, no possibility to edit.
see below;
when i created from scratch an identical connection with entries my 2 columns (without special character) in can replicate.
after that i can edit parameters.
i think problem can come from the fact your column uses a special character in their name.
but has to be confirmed with DevTeam.
i attach the model modified with new columns & new connections. no things added except 2columns beside the tower.
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 13 of 17
stefani.ads
I've submitted this behaviour to the Dev team and they will investigate why this is occurring.
Could you maybe provide some additional information on how this column family (TUBULAR ICHA COLUMN) was created? Was it started from scratch or was it created starting from an existing standard family? If it's the second, could you point out what settings/options you applied to the family?
In the mean time, as another workaround that may be helpful:
If you delete all the Tube end to end connections from the model, then create a Tube end to end connection on 2 tube columns using a standard family (not the one mentioned above) and then go and create the connection on that family afterwards, you should be able to access the connection parameters from Edit Type.
This is because the Preview (the connection image on the left in the Edit Type window) is the one that allows the parameters to be populated in there and when the first connection instance is created, it will point to that one.
Hope this helps.
We will come back with an update here once the current behaviour is figured out.
stefani.ads
Message 14 of 17
bogdan_vacut
The connection is not created because of the special characters [] present in the type name of the column. As workaround open the family and rename the Type name from the Family Types dialog to remove the [] characters : 15x10x18.2. The load the family into the project, go to the model, select the columns and change the type to the new renamed one without [].
Bogdan Vacut
Principal Engineer
Message 15 of 17
AntDrt
This confirm my first impression;
thank you @bogdan_vacut, it will be useful for our team if we want to create custom families.
Antoine
AMG Fechoz
www.amg-fechoz.com
Message 16 of 17
andres_urrutia
thank you for your answer... I have to change all the names of our hss chilean shape...
Message 17 of 17
bogdan_vacut
Can you explain how did you manage to put "[]" characters to the type name because I am not allowed to do this from  Revit - Family Types dialog - Rename Type or New Type?
Thanks!
Bogdan Vacut
Principal Engineer
