Multi-rebar tag - Combine similar rebar sets in one tag
tomragnarsson
Message 1 of 8
tomragnarsson
Hi everyone.
I am looking for a way to place a single multi-rebar annotation for 2 (or more) rebar sets. They have identical count, bar diameter, spacing, position number and suffix. I wish to display this in a format like this:
2 x 20ø10c200, -01, UK ([Number of rebar sets] x [Quantity (one rebar set)] ø [Bar Diameter] c [Spacing], [Position Number], [Suffix]) . Is there a way to do this?
I know how to get it in one line like "40ø10c200, -01, UK", but I want it to show that there are two identical groups with 20 bars in each group, not 40 combined. I also don't want it as two identical, but separate lines because that takes up more space.
Kind regard
Tom
Replies (7)
Message 2 of 8
jay_colc
I think you should be able to get around this with Quantity by Set but i am struggling to see where you can count the number of sets?
Jay Colcombe
Autodesk Certified Instructor
Message 3 of 8
tomragnarsson
I have not found that either. The only parameter that can do it as far as I know, is the "Multi Leader Tag: Host Count". But that one does not work with multi-rebar annotation it seems. It only works with a regular tag if you add more hosts. That will display it as i.e "2 x 20ø10c200, -01, UK", but you don't get the dimension line with that.
Message 4 of 8
jay_colc
I thought a workaround could be to get the Dimensions Count and create a Calculated Parameter “Dimension Count/Quantity Rebar Set” but you can include the Dimension Parameter in this process!
if you change one Rebar set Spacing so they are not identical you do get 2 Tags so you may be able to try and work around this way using Max/Min spacing?
Maybe needs adding as an Idea for future consideration and development!
Jay Colcombe
Message 5 of 8
tomragnarsson
Yes, I also tried what you are suggesting. Being able to use Dimension Count in a calculated parameter would help a lot. I'll see if I can add this as a suggestion for a future releas. I don't think we will be able to solve this one easily at this moment.
Thank you for all the suggestions!
Message 6 of 8
Mr.Borges
I've created a Revit idea about this issue. Please help the idea with your vote.
Revit idea Rebar Set Count parameter
Message 7 of 8
tomragnarsson
Thank you, Mr. Borges. I will be sure to upvote the idea!
Message 8 of 8
joaquim.moral
Hi @Mr.Borges,
Thanks for coming back to the Community and creating a Revit idea! I hope it will help future users with similar issues 🙂
Best,
Your question got successfully answered? Then just click on the 'Mark as solution'
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Joaquim Moral
Senior Community Manager - EMEA / LATAM and Media & Entertainment lead
