Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Modeled-in-place column is visible in all views with the exception of the 3D view
3 REPLIES 3
nkosana.ndlovu
158 Views, 3 Replies
Greetings,
I am working on a model, and i have modeled some structural columns in-place. These are supposed to appear at the corners of the 3D model but they do not. When modeling the columns in-place, the option to input the material as concrete did not appear. Is that the cause of the visibility challenges i am experiencing?  These columns are visible in all other views and sections. I have tried trouble-shooting this with no success. What further approaches can I try?
Tags (1)
Labels (2)
3 REPLIES 3
If you click on the View Hidden Elements (Lightbulb) in the View Control Toolbar do you see them then?
Other checks in the 3D View
Check Phase Filter for the View
VG - Check Filters
Check no View Template is applied
Finally check the Model in Place Element and is Visibility Settings in the Family itself!
Jay Colcombe
Autodesk Certified Instructor
Thank you for highlighting the visibility of the family. I had defined the family as architectural columns (not as structural columns)! Thank you so much
Thank you for highlighting the visibility settings of the family. I had set up the family as architectural columns, not as structural columns! Thank you so much!
Forma Design Contest
Technology Administrators
