Missing stirrup constraints
I'm trying to constraint longitudinal rebar (shape code 00) with beams stirrup (shape code 51). Why Revit doesn't show stirrups constraint grip points??? This "issue" happens very often......
Any help would be highly appreciated!
Regards!
ovidiu_paunescu
Hi @Anonymous
What version of Revit are you using?
If you move the bar closer to the corner, do the points appear?
If you move it without edit constraints, does it snap to the corners?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
Hi @ovidiu_paunescu
I managed to solve the "problem"!......realized that longitudinal rebars and stirrups have to be hosted in the same beam.....
In my case.....longitudinal rebars were in slab and stirrups in beam...:-(
Revit 2020.1
Regards!
