Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Missing properties
2 REPLIES 2
d_lucciS26G3
218 Views, 2 Replies
Missing properties
I imported an IFC file and after opening the RVT file, generated by the program, I do not see all the properties of an object (for example, when selecting a concrete slab I do not read the square meters of surface in the properties). Thanks for your help.
Daniele
2 REPLIES 2
ctm_mka
in reply to: d_lucciS26G3
if you edit the properties of the floor, is the floor definition what you would expect if you created that floor type manually?
d_lucciS26G3
in reply to: ctm_mka
No, but when I create a new floor I read all the dimensional properties.
