making a void extrusion in column
A_MAQ
Advisor Advisor
A_MAQ
hello there
i have column , and i want to make an opening in it
how can i do it ??
 i tried to make void extrusion but it was not able to make cut to make a void
Autodesk Expert Elite
L.Maas
There are different options, which is best  depends on your needs.
Use a structural column instead of a architectural column.
Create (parametric) voids inside the column family.
Louis
Please mention Revit version, especially when uploading Revit files.
A_MAQ
I already draw the column
but i am looking for a way to make an opening in column with out editing the family
constantin.stroescu
use Opening by Face..
Constantin Stroescu
L.Maas
Strange for me it does not work on architectural columns (Revit 2016). If I select the tool "Opening by Face" it will not allow me to select the architectural column.
Louis
constantin.stroescu
you are right for the Architectural Columns.
In such case I use a Component Model in Place ( not a Void because it doesn't work) , Generic Model by preferance and then Cut , taking care of the order of selections ( first select the member that you want to be cut - as can be seen in my screencast)
Finally hide the Generic Model objects....
Constantin Stroescu
It is possible to make a family face based with a void in it! I found it to be the best solution!
