Lineweight differential between new construction objects and existing objects.
I am seeking a way to modify the lineweights of new construction objects and existing objects (with regard to the phase filter) so that the new objects will appear heavier and the existing will appear lighter, more so than the apparent standard setting.   (See attached.)
KrisAribal
You can set it on the graphics override portion on the phasing tool
