Line weights of Dimension Lines
When I'm using the annotation tools on revit to add dimensions to my project, is there a way to adjust the lineweight? Specifically the weight of the line under the number or text but not the leader lines? dimensionline.JPG
L.Maas
Yes you can set the lineweight, but they will apply to both the dimension line as the witness line.
Louis
Please mention Revit version, especially when uploading Revit files.
Is there any way to make just the dimension line a heavier weight? I still want the leader lines to be almost halftoned.
L.Maas
No, basicallly there are two line weight settings available for dimension lines.
One is for the tick marks the other for the lines. So no separate settings for dimension lines, witness lines or leaders. They are controlled by a single setting. Also in the graphics overrides they are not available to be separated
Louis
I just found out that my dimension lineweights do not match project lineweights.
I can set my dimension lineweight to 1.  Then I can draw a detail line that is set to 1 next to it.  The Detail line is about 30% thicker than the dimension line.
What's that about?
Model Line Weights versus Annotation Line Weight.  Make sure they are the same.
Thanks man - losing it with my firms line weights over here.
