joist span tag for beam system
gideon
Message 1 of 9
gideon
is anyone availble to help me to make a beam system tag or beam tag which can show the span (length wise) of joists (not extent which is stored in anootation beam system tag in revit structure.
please find attached a pdf to describe my idea.
Thanks, gideon
Replies (8)
Message 2 of 9
Revit_Whisperer
I don't see a way to do this without having some manual input involved.
You can't add the cut length parameter to the Beam System tag and you can't add the spacing to the Structural Framing tag (and have it automatically fill in the information.
I modified the OOTB Structural Framing tag and added a shared parameter for the spacing which needs to be manually entered and it looks like this....
Message 3 of 9
gideon
hello,
please kindly send me the tag family file.
i think i can modify it by myself.
gideon
Message 4 of 9
Revit_Whisperer
It is attached to my original post along with the shared parameter file...=)
Message 5 of 9
gideon
sorry, i am still using revit 2016.
is it possible that you save it in 2016?
but if not, that is ok.
thanks!
Message 6 of 9
Revit_Whisperer
The attached tag was built in Revit 2015 so it will upgrade....use the shared parameter list from above to do the following in your project.
Message 7 of 9
gideon
thank you for your effort.
I like your tag, but is it possible to make the arrows to extend to the ends of the beam / or joist?
when I insert your tag on my dwg, the arrows does not move or the whole symbol does not stretch.
Thanks, Gideon
Message 8 of 9
A_MAQ
if  you use revit 2017 it will help you in this issue , that you can link family parameter with project parameter which is in your case cut length parameter
hope this helped you
best,
Autodesk Expert Elite
Message 9 of 9
gideon
if someone can solve this problem for revit 2016, I would greatly
appreciate it.
Thanks for the efforts of you guys.
