Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Joining means
8 REPLIES 8
Message 1 of 9
488 Views, 8 Replies
Joining means
I would like to know if anyone has experience in creating joining means. My interest is in multi-layer walls with, for example, screw connections.
Best regards, Lavinia
8 REPLIES 8
Message 2 of 9
MostafaElashmawy
Hi @Anonymous ,
Your question is not clear, try to provide more explanation and a sketch if possible.
Mostafa Elashmawy
Message 3 of 9
Hello @MostafaElashmawy
Unfortunately I can't show any drawings because I haven't found a way in Revit yet. But my idea is that I can integrate for example insulation dowels into the wall construction. So far I have not found a possibility for screws, dowels, etc. for wall constructions in Revit.
Message 4 of 9
ennujozlagam
you can draw that in drafting view? no need to draw in plan view , just use call out to show the details in section view? thanks
Message 5 of 9
Hello @ennujozlagam
I'm not sure if I understand you correctly. So far I don't have much experience in Revit.
I just want to know if it's possible to draw a screw, for example, and link that information to my wall construction.
Thank you.
Message 6 of 9
ennujozlagam
cut a section view (as sectional details)s and add what ever you want to add like for example insulation. screw, plate but to draw that in plan view . make your detail as typical details. thanks
Message 7 of 9
ennujozlagam
https://www.youtube.com/watch?v=OOp5zWXqIsY
Message 8 of 9
Thank you for the link.
Okay, then the drawing itself should not be a problem. However, my idea is that I have a wall construction with its layers and data stored. I would like to assign the connectors to these. So it should not be a simple 2D-drawing, but elements that I can integrate to my wall construction (BIM compatible).
Message 9 of 9
ennujozlagam
can post some screenshot for better understanding on what are you trying to achieve. thanks
Forma Design Contest
