Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Join beam geometry
6 REPLIES 6
juancano_arq
974 Views, 6 Replies
Join beam geometry
Hello everybody!
Hope you're fine.
I'm modeling a roof, highly detailed and all modelled roof, "like the real life". I'm using beam system to model the rafters, but I need that the rafters cut/join (idk what method) the concrete beam. How would you do it?
I let the images below.
Thanks!
Labels (2)
6 REPLIES 6
ennujozlagam
in reply to: juancano_arq
have you try to use join geometry pick rafters and then beam and see if helps. thanks
PavelAnd
Hi @juancano_arq. Check that your beam is not showing as a line in coarse detail level (otherwise you will not be able to join it).
Best regards, Pavel Plotitsyn.
juancano_arq
in reply to: PavelAnd
Amazing @PavelAnd !!
Thank you so much!
juancano_arq
in reply to: ennujozlagam
Thanks @ennujozlagam for answer!
Yes, I had tried that and other methods, but the correct way was like @PavelAnd recommended.
ennujozlagam
that was my first suggestion to you. thanks
gouthamX3UHU
i am not able join beam
