Issues with Coping of Steel Elements
Hello everyone,
I have been having an issue when coping channels into columns. The hidden lines dissapear when coping channels. I've attached a picture to illustrate.
The bottom left member is HSS, bottom right W-beam, the top right is a coped channel and top left is an uncoped channel. The issue seems to occur only with channels.
Am I missing something?
Thank you in advance for your help.
RDAOU
Hello @Anonymous
I never came accross this before. And I'm not sure maybe I am missing out on something... I tried to create the same what u got there to see the error but it's not working (as in I can't seem to be able to get same result like you)
Can you mabe attach the file to have a look at it?
Hi RDAOU,
thx for commenting this post
I believe Evi_mata has placed the member orienting 'h' is flat see attached rvt file 2016
RDAOU
@Anonymous Thanks for the file
@Anonymous
  1. Go to the Properties Dialog
  2. Scroll down to Show Hidden Lines
  3. Change from by Discipline to by Element or All
If you find this reply helpful and it answers your query please mark as ACCEPT AS SOLUTION
Thank you @RDAOU and @Anonymous for your help!
I was hurting my brain trying to figure this one out and it was such a simple fix.
RDAOU
You are more than welcome... Should you have more questions please do not hesitate to post them
Sent from my iPhone
