Is it possible to change material visibility on shaded mode like realistic mode?
Solved by GustavoUbriaco. Go to Solution.
Hi! in material editor graphics, you select USE RENDER APPEARANCE, this will makes the similar color to realistic view, also you can use patterns for surface.
Gustavo Ubriaco Contreras
