Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
intersecting concrete columns and beams and slabs
3 REPLIES 3
ahmedgamalbakr
960 Views, 3 Replies
the concrete wall is intersecting the column and the geometry has automatically joined. This has resulted in a miscalculation of concrete volume for the individual elements.
how can i solve this problem i wanna the revit calculate the volume of the column according to clear height not total height ?
3 REPLIES 3
Have you tried UNjoining them?
Maybe it solves your issue if you use the command Switch join order in the Modify tab?
Beste Grüße
Björn
Senior BiM Consultant bei
www.bimotion.de
E-Mail | LinkedIn | YouTube
dzanta
in reply to: bjoern_teutriene
go into the column family and uncheck "automatically join geometry to walls" then reload into project.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Forma Design Contest
