Hi!
I'm essentially a beginner to Revit and I'm working to model my parents cabin and perform an energy audit. I was able to find a lot of information on creating studded walls with insulation, via the curtain wall method, but I can't seem to find any information on creating studded floors with insulation (and will probably encounter the same problem for roofs). I apologize for any improper naming, I'm in no means educated on construction terms. I found the material "Structure, Wood Joist/Rafter Layer, Batt Insulation" in the edit tab of a composite floor, but due to the lack of rendering detail I can't confirm if this is what I'm looking for. I don't need it to be visually accurate, but if someone can just confirm that this is what I should be using, or recommend an alternative method, that would be greatly appreciated!
Brad
i usually use wall layers to define insulation of the walls
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
