Hello everyone,
I have a schedule which lists my lintel beams for a residential design, I have since added trusses to the model for section views etc I have no need to count them anywhere, but it seems that the individual web pieces are showing up and I cant seem to filter them out.
Googling says I cant filter by family or type, so I created a shared parameter called "element type" as text, and I have given it the value " truss". it seems the whole truss has the value but each element inside it (the webs) don't share it so I cant do it that way.
I don't want to individually mark every web is there a better way to hide the truss timbers in my schedule? (Not sure if it matters but I coped the truss webs so they looked better in the section views, I had to unpin them but I re pinned them once I was done)
Cheers
Grant.
Solved by ToanDN. Go to Solution.
Solved by Jamhmer_Oc. Go to Solution.
Hi @grantkjones
You can use any parameter that is available, it can be comments, type of mark, etc. In the attached file I use the brand parameter and with this filter in the schedule.
Jamhmer Oc
Thanks Jamhmer, I did end up using the comments field for filtering as you suggested.
Instead of typing in the Comments for every truss member, you can duplicate the framing types, give them an Unique names or Descriptions, and assign the particular Types to be used by trusses. That way, you can filter by type name or Description more systematically.
