Inconsistent unit
Inconsistent unit
dinh.thang.au
Inconsistent unit
dinh.thang.au
Hi everybody,
As the title, I dont know what the problem with below formula.
IF(AND(BBox,r=0mm),r=1mm,IF(AND(RBox,r=0mm,3*t1,r))
Any ideas will be much appreciated. Thanks in advanced.
Dinh Toan Thang
Is dum_r a number or length parameter? It should be length for the formula to work. If it is a number patameter then you need to neutralize the unit in the to formula by divide each by 1.
dinh.thang.au
@ToanDN Thank you for your reply. Unfortunately it is length parameter. 😞
Dinh Toan Thang
Can you share the family?
dinh.thang.au
@ToanDN
Thank you for taking time look at my family. It is at the very early stage.
Dinh Toan Thang
if(and(BBox, r = 0 mm), 1 mm, if(and(RBox, r = 0 mm), 3 * t1, r))
dinh.thang.au
@ToanDN Thank you for quick reply
It seems to be syntax problem since My Pc is also installed Japanese typing.
-Dont beleave others, just ToanDN is enough- Dinh Toan Thang :))
Dinh Toan Thang
