Import problem: Robot to revit
Message 1 of 9
I'm trying to import my calculation model from robot structural analysis professional 2018 to revit 2018, but I keep getting an error. The error message prompts me to enter a value, but there isn't a place to insert it. I have attached a screenshot of the problem. If I click expand and delete the two problems that can't be ignored then nothing is imported to revit. I have tried all of the options in robots export field.
Replies (8)
Message 2 of 9
teodorb
Dear @Anonymous,
Coould you please provide the Robot model. We would need this to investigate your issue.
Thank you,
Bogdan Teodorescu
Product Owner
Message 3 of 9
I have sent you a private message containing the link to the model. I'm not allowed to share the model publicly.
Message 4 of 9
teodorb
Hi @Anonymous,
Thank you for this. We' ll investigate the issue and come back with details.
Kind regards,
Bogdan Teodorescu
Product Owner
Message 5 of 9
Artur.Kosakowski
Autodesk Support
Autodesk Support
Hi @Anonymous
Try these steps:
1. Open RSA model
2. Navigate to the bar table and switch to the Edit tab
3. Change gamma angle for bars 9088 and 230 from 449.9 deg to 89.9 deg (449.9 - 360)
4. Export the model to Revit
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
Artur Kosakowski
Message 6 of 9
Hello Artur,
The solution worked, and now I know another thing to keep an eye on for future conversions. Thanks a lot!
Message 7 of 9
I'm a student working on a project and I'm still a beginner and my robot project will not  integrate with revit it always displays a run time error. please help me out . I even tried reinstalling revit it still did not work. I use 2019 version of both Robot and Revit.
The integration works fine when i  use prismatic sections by using the frame generator. I don't know what is wrong in my modelling please help me out
Message 8 of 9
kmackowska
I have similar problem but all my bars have degrees of following values: -270, 0, 3.8, 73.2, 90. None go over the allowed number of degrees. I tried integrating robot and revit both by sending it straight to revit and by creating separate .smxx file. Both methods failed. Do you have any idea what might be causing my problem. I am stuck
Message 9 of 9
efaustoD3RAG
I got the same "Unknown run-time error" when trying to import Robot back into Revit, and I found it was caused by empty load combinations. I had to either populate or delete the empty load combinations to import back into Revit successfully.
