Hi @nazeernaz
Unfortunately there is no option to find those images in a folder and use them.
As an option, I would recommend that you capture the previews that appear when you hover over the connections.
Jamhmer Oc
yeah, that's what I too did. Snipped the captures. (For more better learning).
I can understand that Autodesk wont allow end users to access hardcoded files to ensure copyright and quality based issues.
I have gone through Autodesk help sections also.
But there too full of theory based helps only.
I hope in future versions Autodesk implement more raster imaged helps or let users access tooltip images like videos.
@nazeernaz These are actually assembly resources and can be viewed with the enclosed macro.
Note that resource names may not exactly match the names of the connections and there may be some region specific or unsupported items not applicable i.e. not all images may relate to a connection type.
