Hi!
We have a problem with IFC 2x3 export from Revit 2023.
When we export the model, some elements (element assemblies) are located in the wrong z-value. We have tried several different export settings and have tried to open the ifc in several different programs with the same result.
We have Revit 2023 with the IFC extension version 23.2.3
Any idea what of a possible solution to get it exported to the correct z-coordinate?
I confirm that issue is still remained.
I devide walls by parts to make needed shape for prefab concrete elements and than create assemblies. After IFC export same issue with some elements shifted in Z coordinate. Updated latest revit version, IFC exporter version, tried different settings but still no results.
Does anyone solved this issue? Would appreciate any help!
I have seen a couple of references where the latest update did not resolve the issue and then found a very recent Autodesk Knowledge Base Article which confirms there is still an issue with IFC and Shared Coordinates which is still being investigated.
