Hi @Anonymous
Revit is not really set up to do the fabrication drawings of steelwork, only the modelling.
If you have an AEC collection the best workflow would be to transfer your model to Advance Steel then Advance Steel will run the fabrication drawings automatically for you, it will split the model down into the piece parts and the assembly drawings.
We have done many webinars in the past on this workflow, see link to your Advance Steel content centre below
https://www.graitec.co.uk/cad-courses/training-tutorials-and-webinars/advance-steel-content-portal#sliders-technology-3
If you go to the Revit section the webinars that will get you going are
Revit to Advance Steel Collaboration Part 1
Revit to Advance Steel Collaboration Part 2
Create Fabrication Drawings from Revit using Advance Steel
Rob Merriman, AEC Technical Lead, Graitec
