How to show beam hidden line in floor plan
shuaib009
Message 1 of 9
shuaib009
How can I show beam (RB) hidden line in floor plan. My view range is at mid of window.
The desired output should be as below.
Replies (8)
Message 2 of 9
ArmanMargaryan
Message 3 of 9
ennujozlagam
you can try linework. thanks
Message 4 of 9
ennujozlagam
or you can try filter per view? here is the example. thanks
Message 5 of 9
shuaib009
Thanks @ennujozlagam @ArmanMargaryan .
However, I used Regain plan tool to show the beam in plan then I changed beam appearance changing beam line to hidden in visibility/graphics setting. It worked fine for me. thank you.
Message 6 of 9
ennujozlagam
good that's another way to do it, create a plan region set the view range and VG change the line to hidden. thanks😉
Message 7 of 9
shuaib009
accept my solution. thanks. 😂 😜
Message 8 of 9
XSXCHU001
Community Visitor
Community Visitor
I have a similar issue. My beam system boundary line is visible when I click on it but when I want to use it as a reference it only shows the beams that run within it. I want the boundary line to show. Please assist
Message 9 of 9
jay_colcombe
It is not possible - you can turn on Location Lines for the Structural Framing member within the Beam System but not the Boundary Lines
Jay Colcombe
Autodesk Certified Instructor
