Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How to make a sloped cut to a column at its top?
4 REPLIES 4
roquealfonso
3297 Views, 4 Replies
I'm currently modeling a parking lot that has a sloped floor, beams and slabs must follow that sloped as well. I'm having trouble trying to model properly the column with a sloped cut at its top (pictures below), how can I work it around.
Yet with, bearing walls, it seems to perform this as it should (picture below also).
Structural Columns (can't make a sloped cut at the top):
With bearing walls there is no problem:
4 REPLIES 4
PavelAnd
in reply to: roquealfonso
Hi @roquealfonso. Look some workarounds below.
Best regards, Pavel Plotitsyn.
rkhattar
in reply to: PavelAnd
Hi @PavelAnd
Try the attach and detach options.
I find it works really well for structural columns.
Can be done for reference planes, could also be attached to U/S of slabs and beams.
Have to make sure of the following:
  • Attach Column - Top or Bottom
  • Attachment style - Cut Column
  • Attachment Justification - Maximum Intersection
Hope this helps.
ennujozlagam
you can refer to screencast video and see if helps. thanks
roquealfonso
Thank you for your feedback! I figured out a way for working this around.
I changed the column style from Vertical to Slanted End Point Driven, and switched for a tangent attachment at the base and top, when attaching the column to a reference plane that follows the same slope as the ramp. Picture below of the end result:
Forma Design Contest
Technology Administrators
