I am following the instructions below but there is no weld type. I loaded Autodesk Family Weld Tag which is annotation. Where is the weld family?
Solved by Tom_Kunsman. Go to Solution.
My guess is that you did not load a Generic Annotation symbol. Which version of Revit are you using?
Because that is not a Generic Annotation. That is a Tag. Try this -
No, something I made a while back
