How to hide inner walls seen through openings in Elevation?
shuaib009
shuaib009
How to hide inner walls seen through door & window openings in elevation.
See the attached snapshot.
ArmanMargaryan
Hi!
Can you upload an example file or picture to us to look at?
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
ennujozlagam
you can select the objects and right click in your mouse > select hide in view? thanks
shuaib009
Thanks @ennujozlagam for your solution
Thanks @ArmanMargaryan for your intrest, sorry I forgot to upload the file.
