How to hide inner walls seen through openings in Elevation?
shuaib009
shuaib009
How to hide inner walls seen through door & window openings in elevation.
See the attached snapshot. @peticid @teodorb
jbrazier
Change the Far Clip Offset in your elevation properties.  If you set your Elevation to Clip With Line you can adjust the depth of the elevation graphically in plan.
Jon Brazier
Director of Production Technology
O'Donnell & Naccarato
Philadelphia, Pa.
ennujozlagam
you can select the objects and right click in your mouse > select hide in view? thanks
shuaib009
Thanks Mr @jbrazier & @ennujozlagam for the solution.
