How to create advanced custom detail components
susan.roosen
susan.roosen
Can someone point me to a tutorial or a class to learn how to create custom, more sophisticated, detail components?  By more sophisticated I mean ones that are easily adjustable and have visibility options and constraints and parameters that can be changed in the drafting view in a project.
So, as a simple example, the OOTB 'C Studs-Side' detail component can be inserted in the drafting view, then the length can be easily adjusted using the little dots on the ends, you just drag it.  But how do I get those dots to change the length in a custom detail component that I create from scratch?
Or another example, I downloaded a pipe break component from Revit City and you can drag one side using the double triangles, and the opposite side moves along with it so they're constrained somehow but I don't know how to create that from scratch.  There are more advanced components too that I'd love to learn how to create, I just need help finding where to learn.  I am using Revit Structure 2019 and 2020.  Thanks!
ennujozlagam
https://www.youtube.com/results?search_query=How+to+create+advanced+custom+detail+components+with+pa...
susan.roosen
Thank you!  I will check these videos out.
