Graphical Column Schedule
ArmanMargaryan
ArmanMargaryan
Hi!
I want to add Base Plate Connection settings (Bolts, Length, Thickness, Width) to the Graphical Column Schedule. Is it possible to do this in Revit?
Thanks.
Arman Margaryan
Structural Engineer | BIM Specialist
If my answer solved your problem, please click the "ACCEPT SOLUTION" button.
Linkedin | Facebook
Revit Structure Certified Professional
dtpeter2901
Yes it is.  The trick to doing it is to make the column base plate it's only column family.  And then create a tag to take the column so it reads the shared parameter information from the column base plate family.
But because that will be the lowest column
ArmanMargaryan
 How is the mentioned information done, it is done through the tag?
Arman Margaryan
Linkedin | Facebook
dtpeter2901
Yep.  Just like the tag for the steel column.  only this one is for the base plate.
ArmanMargaryan
Thanks, maybe there are other solutions.
Arman Margaryan
Linkedin | Facebook
