How to export revit structure model into plant 3D as structure member?
thiago.ribeiro4TG7Z
thiago.ribeiro4TG7Z
Hi, folks
I'm trying to export a structure model from Revit to Plant3D, but with the DWG export the model are composed by blocks, but I need structure members. How can I reach it?
Thanks in advance.
hmunsell
You can try an IFC export from Revit and pull it into Plant 3D?
Howard Munsell
thiago.ribeiro4TG7Z
Hi, @hmunsell. Thanks for answering.
I believe that such a solution will not work for me.
Plant3D doesn't read IFC, I can't find it at least. And if I could import IFC, could I modify it once inside Plant3D?
hmunsell
I'm not familiar with Plant 3D either, only played with it a little. I was just throwing it out there as something to try :-).  I couldn't find anything in a quick search for Importing IFC into Plant 3D, sorry :-(.
Howard Munsell
