Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
how to export Revit element to Autocad (DWG) as a block
11 REPLIES 11
Message 1 of 12
ahadi.siregar
5229 Views, 11 Replies
When exporting the structural components from Revit, it didn't created any blocks.
Once I had exported it, it did. But I don't know what did I do, it automatically created blocks. Like a column I created in Revit, it turned into blocks in CAD.
But now it only turned into line and hatch, which is I didnt wish
11 REPLIES 11
Message 2 of 12
While exporting, go to export setup>> solids>> choose ACIS solids.
Mostafa Elashmawy
Message 3 of 12
I've tried,
it didn't work, sir
it still turned to hatches and line
not a block
Message 4 of 12
Sorry, what I mentioned is related to 3D. I didn't notice your attachements.
Your problem can be solved by editing each family that is exported exploded and tick the option "Always export as geometry".
Mostafa Elashmawy
Message 5 of 12
if not working, share the file.
Mostafa Elashmawy
Message 6 of 12
ouch sorry I just realize there is insert photo button 😅
still didnt workout for me..
Message 7 of 12
I tried to delete the floor and some works out
but it doesnt work out if I only uncheck the floor in visibility, it only works if I delete all floors..
maybe it has something to do with the floor or something?
you have any idea?
here, only some column turned it blocks after I delete the floor/slab above level
Message 8 of 12
can you share the revit model?
Mostafa Elashmawy
Message 9 of 12
I want to know if these columns are below the slab.
If they are below the slab, how could you see them? are you exporting from wire framed view? is the floor transparent?
Mostafa Elashmawy
Message 10 of 12
yes the slab (ref. to 2nd floor) is above the column, I was exporting on zero level.
I remember, once I was able to exported them all to blocks,
dont know what's wrong, unable to do it now..
here my file
Message 11 of 12
erkan.s
in reply to: ahadi.siregar
It happens to me in Revit 2019. Can you find a solution? @MostafaElashmawy
Message 12 of 12
PaulineP54QC
in reply to: erkan.s
Just wondering if anybody came up with a solution. I do electrical work so Fire Alarm is always part of it.  At the end of the project we always need to send the FA cad files to the vendor so they can do the submittal and it is really terrible that all FA devices are exploded. Thank you!
Forma Design Contest
