Hi forum,
I want to create starting rebar for fillet retaining wall as in the first picture. Freeform rebar works for me only if I adjust footing but that doesnt work to me (see picture 2). How can I achieve it in thegeometry such as in the picture 3? What am I doing wrong? Can someone please help me out?
Dan.
Solved by ovidiu_paunescu. Go to Solution.
I can think of two ways to model that:
The first would be free form rebar + hooks
The second option would to create additional geometry for defining the bar geometry
In your example, it could look like the image below.
The end offset can be adjusted through edit constraints, so only the defining host faces are important
Like in the previous example, you can use the "Bend" option to match the bar geometry to a rebar shape.
In my simple example the L bar matches the M_17 shape
Let me know if you have any questions
so both of the proposed solutions work, but they are half-way solutions.
I found another somewhat interesting solution. You place one bar, make it a radial array and then you can use sofistik rebar addon to make it a group for scheduling. But it doesn't work with with other than circular walls.
In the end, all of the solutions are not complete and revit team should come up with some solution.
Thank you for the help,
Daniel
