How to Create Diagrids in Dynamo?
I am trying to modelling a column which seems like an elephant feet via Dynamo. I need to create diagrids. For able to do that, instructor recomended a package called Lunchbox. But, it seems, it is not available in dynamo anymore. Which package or which way can I use as a solution way if I need to create diagrids?
PS: I also added the column pic which I'm trying to create.
What version of dynamo and revit do you have?
I'm working on Revit 21. And, dynamo version is in the attachment pic.
RPTHOMAS108
I've seen someone using an older version of Lunchbox with a newer version of Dynamo recently:
https://forums.autodesk.com/t5/revit-structure-forum/exporting-reinforcement-schedules-to-xml-file/m...
The source to Lunchbox is available online so you could probably find someone to make the updates and compile for later version. It's a shame it's no longer available because when I went somewhere to be taught the Dynamo basics that is the package that was recommended at the time also. Although I remember thinking but what if it suddenly becomes unavailable, will half my graph end up yellow/gold...
Some people probably get by with pattern based adaptive components for diagrids.
Thank you for letting me know
