How to create boundary condition family?
When I select boundary condition it tells me incomplete boundaries
A_MAQ
ou are trying to add Boundary Conditions, it is support for structural analytical model.
You are using a project template without Boundary Condition families loaded.  They are used for graphical representation of supports.
They are installed with Revit.  The location depends on version and language content, for example it is: "c:\ProgramData\Autodesk\RVT 2016\Libraries\US Metric\Boundary Conditions\.."
Then you may set proper family for Boundary Condition visualization.  Go to Manage tab and choose Structural Setting command.  Set family symbols on Boundary Conditions Settings tab in the dialog window.
Autodesk Expert Elite
cherneymoua98
Community Visitor
Community Visitor
my Revit has no boundary condition families
ennujozlagam
try to use Structural template if you want to build structural model and use analytical elements.
it is loaded the Boundary Condition families in Structural template. and see if helps. thanks
karls1986.12
Don't forget to close the topic by marking the answer that helped you.
This will help other users to find an answer.
