Dear all,
I have searched the UB families in Stuctural Framing>Steel>Universal Beam, but it doesn't consist of the UB686x356x384kg/m, UB533x312x196.4kg/m and UB254x203x49kg/m.
So, is it acceptable if I create open the existing UB family in library and edit its H and B ?
Click File>Open>Structural Framing>Steel>Universal beam template>Edit h x b>Save as a new family.
Just like the attachment below.
Tqvm.
Solved by ennujozlagam. Go to Solution.
edit your beam family > go to 1) family types > 2) change the value > 3) create a new type name. thanks
Many thanks!!!
Do i need to insert the weight for UB as well in the family type?
Regards.
it's up to you, if you have the specs of the beam? for the meantime no need you change later just edit the family inself. thanks
once you loaded your beam family < go to edit type > and then you select the beam you created with new file name? thanks
here is screencast for you. thanks
