How is this done?
How is this done?
jvgg
Message 1 of 8
How is this done?
jvgg
I received a model made with Dynamo where I have a wall, it is in the wall category, but it is not a wall, how is it done?
When selecting the wall, only this button is activated.
the foundation is the same.
Replies (7)
Message 2 of 8
Ahmed_Muharram
can you check if its exported as IFC
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 8
RPTHOMAS108
Looks like a DirectShape
"DirectShape is not a replacement for "real" Wall, Roof, Window, etc. It would typically be used where there is not enough information to create, e.g., a Wall, or full functionality of a Wall object is not needed. Some category-specific functionality may be available. If you need to modify a shape held by a DirectShape object, use Revit Geometry API, and then store the modified shape back to the DirectShape object."
I think in that instance highlighted it likely could have been an actual wall unless that element is doing something exceptional outside the scope of that image.
Message 4 of 8
hmunsell
It could be a Model-In-Place "Component", categorized as a Wall.  Essentially its an extruded shape, that is told be behave like a Wall.
Howard Munsell
Message 5 of 8
RPTHOMAS108
If it came from Dynamo then it isn't likely to be an in-place family since I believe that the API has no way of creating those. Also would have 'Edit In-Place' on the modify tab.
I guess it doesn't really matter either way the result is the same.
Message 6 of 8
hmunsell
Dynamo has limitations 😱.... LOL.
didn't realize Dynamo couldn't do In Place components, Interesting... good to know though 👍.
Howard Munsell
Message 7 of 8
RPTHOMAS108
Yes can never rule out that someone has found a way of doing something that isn't supported by the API but generally wouldn't be possible.
There is an example of an add-in which 'protects' Family content in a project, likely by manipulating the Revit file directly outside of the API but that is quite an extreme example.
Message 8 of 8
I think it is a Direct Shape as well.  You cannot alter it, except maybe create parts, turn on parts grips, and modify it.
