Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
How I can import a 3D Structural model Autocad to Revit for do connections?
6 REPLIES 6
vipsa
1028 Views, 6 Replies
How I can import a 3D Structural model Autocad to Revit for do connections, I am exporting as DWG and Family, but anyway can't doing connections. The files exporting are as Blocks
Thanks.
6 REPLIES 6
Sahay_R
in reply to: vipsa
You would need to link your DWG into the RVT.
Insert>>Link CAD
On another note - a structural model from AutoCAD, Microstation, other non-Revit programs, would not give the structural members the intelligence of Revit objects. Is this a model from a consultant, and you cannot change or edit it?
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
vipsa
in reply to: Sahay_R
My project is ASD but I want to know the compatibility between both software, I know that ASD is discontinue, so I am testing if  really is good keep using ASD or work all the project on Revit. My project ASD have not connections, this is the reason why I want o know how make connections on Revit since a 3D ASD model
Sahay_R
in reply to: vipsa
Work entirely in Revit. You will be able to create structural components with intelligence and identity information. It will make things much easier for yourself.
Rina Sahay
Sahay_R
in reply to: vipsa
More information. Look at the section for Structural Engineers.
http://blogs.autodesk.com/revit/2017/04/13/introducing-revit-2018/#
Rina Sahay
artejon
in reply to: vipsa
Isn't  Advance Steel meant to deal with connections and other things like that ? It has a bidirectional link with Revit.
Revit add-ins: CAD Purger (delete UNUSED and selected line patterns & line styles, find and delete CAD), Rooms To Spaces, Schedule Utilities (Calculated Values/Combined Parameters To Tags, reuse view filter rules in schedule filters), View Filter Manager at Revit Apps Store
MostafaElashmawy
in reply to: vipsa
you can use the cad as reference to model your elements in revit. but cad can't be used as a revit element.
Mostafa Elashmawy
