- Mute
- Permalink
- Report
I'm currently working on a logistics plan with the use of a structural REVIT model. The final location of our tower cranes will be based on the weights of the structural members. The easiest way to do this, by adding the weight to Tag on a framing plan.
Part A; Calculating the framing and creating a schedule was fairly easy. I used the link below for as a crash tutorial.
OK, here's where I'm locked up. I try to apply the same formula (Density/1)*(Volume/1) to the Structural Framing Tag when go through the edit the Tag family But I end up with an error:
" The following is not a valid parameter: Density" "Note that parameter names are case sensitive."
I tried following the same approach as the tutorial on the link below, but I don't think Room Tags and Structural Framing Tags work the same.
https://www.ideateinc.com/blog/2016/04/pushing-calculated-values-to-tags-using
Any Suggestions would be greatly appreciated!
