Revit bending detail not working
diego.veloso.98
diego.veloso.98
Hi. I'm trying to use Revit bending detail for a specific rebar shape that I draw using free form, but the bending detail image wont work. It's like the image below, the image stays as a exclamation mark.
Thank's in advance for any help !!!
Replies (7)
Ahmed_Muharram
free form is not working yet as I know we can confirm from @ovidiu_paunescu
Ahmed Muharram, B.Sc, AEE, ACI, ACP
BIM Manager
ovidiu_paunescu
The bending detail is available for free form rebar, only when the workshop instructions is set to "Bend" for the bar.
In this example it looks like the BD can't be computed for the particular bar. It may be related to the large angle between the bar segments (almost colinear)
Can you attach a sample file with this bar?
Ovidiu Paunescu, M.Sc. Str. Eng.
Sr. Product Owner | Autodesk Revit
handjonathan
Hi @diego.veloso.98
Thanks a lot for posting your question to the forums!   Has the solution suggested by @ovidiu_paunescu  helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
diego.veloso.98
Hi ovidiu, sorry for the late reply, didnt see that I got awnsers at my post.
Thats weird, because there`s not any sharp angles in my rebar form. It seems to work when I shorten the length of It, not necessarily removing any curves. The file is attached.
you can see the problem at the first sheet ( DETALHAMENTO LAJE ).
Thank you !!
ovidiu_paunescu
Hi @diego.veloso.98
Unfortunately there is an issue with bending details not working for bars with segments that are almost colinear. This is due to some tolerances used to define the BD geometry. This will be fixed, but I can't give specific details about the Revit version.
In a simple example, if I sketch a bar from scratch and adjust the angles, the bending detail stops working at about 179.05 deg.
In your case it was 178.854 deg
As a workaround, you could create another section view where you show only that bar, add some text for segment lengths and a tag, and overlap it with the other section, on that sheet.
diego.veloso.98
Thank you, ovidiu ! I was just joing to ask you about that workaround. Cound I, for instance, make that rebar a displaced element but also keep a view of that in place? That would be almost the same of the bending detail.
Again, thank you!
ovidiu_paunescu
No, because when you displace an element in a view, you only see the displaced element, not the original.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
