Revit Structure Forum
Welcome to Autodesk’s Revit Structure Forums. Share your knowledge, ask questions, and explore popular Revit Structure topics.
Hosted Line Load Partial Length
2 REPLIES 2
fritzQH7E9
294 Views, 2 Replies
Is there a way to add a hosted line load to a beam that is not the full length of the beam?
2 REPLIES 2
hmunsell
in reply to: fritzQH7E9
can you provide an example of how your using it?
Generally speaking, you should be able to add a Model line to the family, then use constraints to define the offsets from the ends.
Howard Munsell
fritzQH7E9
I'm typically have beams where the loading varies along the length of the beam. I'm trying to put this loading in in Revit and then export it to Robot. The problem I get is when I export it's pretty common for line loads that aren't hosted to not be transferred into Robot
Forma Design Contest
