hollow core floor - show cores in section
Karol_Piroska
Advisor Advisor
Karol_Piroska
Hi, I think this was discussed on the forum a few times in the past, but I wonder if anyone has any other way to show cores in hollowcore floor slabs other than manually adding these as detail items (repeating detail) or using precast extension. I still think that there should be a way to do that considering one can show metal deck profiles in section.
thanks
Ahmed_Muharram
i think you mentioned the available solutions in your post ...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Tom_Kunsman
this is from the OoTB content. It shows the cores. If you want to see the cores use families that have them in them. Use better content slab.JPG
EdwinG
I use "beams"  in the netherlands you can download the family from
https://vbi.nl/nieuws/vbi-revit-families-beschikbaar/
