Beam and Floor Connection
IrakliA
IrakliA
Deal all,
I am trying to connect floor and beams by Join tool. However, they are displayed differently (See the picture below). I am trying to accomplish the visual as the right beam (blank, without a line between beam and floor). Do you have any ideas how can i do that?
Thank you in advance
Ahmed_Muharram
they should be the same structural material
and on modify tab use join
if you need to switch the join use switch join from modify tab
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
IrakliA
Both beam and floor are the same material. Just one beam is connected the other seems not to be. I used the join tool and end up with the results shown in the picture.
Ahmed_Muharram
could you share the file ?
ipselute
Go to Properties Palette -> Structural -> Structural Usage: Girder/Joist/Other/etc. Different Usage of the beams may result in different appearance (different hatching). Try to match the Usage for both beams.
