Hidden line style and pattern hatch
I want to show the wall cut pattern in hidden line style while transparency is active.
hmunsell
the properties window your showing is not showing the wall settings. the 20% transparency seems to be assigned to the Lines category. Walls are all the way at the bottom of the visibility categories.
try setting up a View Template with the settings you want and apply it to the view.
Update: Interesting..... Murs translates to Walls, since the categories are alphabetical, it is putting it where i would normally see Lines in the English version.
Howard Munsell
hmunsell
The Transparency setting only applies to Projection/Surface, Not Cut walls.
what is your View Range settings? if the walls are being Cut by the Cut Plane the transparency will not apply.  would checking the Halftone box on the Right work?
Howard Munsell
